Old 07-08-2006, 04:01 PM   #1
'68 CortyMan
Default 1600 - 2ltr sump
Does anyone know if the 1600 xflow sumps will directly attach to 2ltr pinto?
'68 CortyMan is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2006, 01:58 PM   #2
smh00n
State of Confusion
No. Different all over
smh00n is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2006, 07:18 PM   #3
rag top
rag top's Avatar
Also, if it helps, cortina and escort 2l sumps are different.
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 09:42 AM   #4
whooligan
whooligan's Avatar
The Mk 2 Cortina requires a front bowl sump, whereas the Escort has a rear bowl sump (both 1600 and 2lt).....Basically, to fit a 2lt in a Mk2 Cortina you need to modify the pinto sump and use a straight x-flow pick-up pipe (from your cortina)
whooligan is offline   Reply With Quote Multi-Quote with this Post
