'03 BA XT
Hi guys,
I bought a futura with Pioneer stereo but no speakers. I've put two 6' in the back and two tweeters under windscreen. Now I want to put some in the front door but I'm not sure how to open the speaker cover, I don't want to force and break it. Should I unscrew the whole door panel? How big speakers can i put there 6' or 4'? thanks |
ThUmPeR
yoy have to take the enite door trim off to get the the speaker, the cage is just for looks and to let sound out.
and the speakers are 6" or 5.1/2" cheers troy
1994 ED Falcon ICE: 7" DVD BIG MTX sterio OTHER: 2.5" exuast, Pacemaker extractors K&N Flat pannel 20" Gianna wheels Dropped on Pedders BA Bonnet bulge clear indicators all round Full EL Ghia interior |
'03 BA XT
thanks reded,
ThUmPeR
no problem mate, have fun.
Aspiring mr efxr
factory are 6" but 5.25" fit fine...
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
Parts bin special
The doortrim's easy to take off. It's only about a 2-5 minute job
ThUmPeR
hey pat were did you get the 5.25" splits from?
was it jaycar? when i went in there all he had were 6" :( cheers troy
#8 | |||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
I have 6 1/2" speaker in mine which can be fitted either by cutting the holes bigger or using a 6 1/2" 6mm spacer But watch out as cutting metal to fit bigger speakers legally makes your car unroadworthy
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
#9 | |||
ThUmPeR
only if they know its been cut.......;)
#10 | |||
ThUmPeR
if you do a good enough job they wont notice or wont care.
Aspiring mr efxr
troy, autobarn. sony Xplod's. was over charged for em... i just saw em and got em... $200 for 150w splits lol!
#13 | ||
I replaced mine in my el fairmont the other night!
I just used teh Jaycar 6" 2way speakers, $39.95 and go great. they are rated at 35rms and cause i only have my sub running of an amp they are fine cause a standard head unit output is only approx 20 - 25rms x 4. The only issue is you will probably need a drill cause ford kindly attach there speakers at 120degree intervals (3 screws, in my EL Fairmont, not sure on others) and they use those pain the butt weird headed screws. I was careful and just used a set of pliers to unscrew and rescrew. The $40 response speakers a world above the standard pioneer ones and go great! Goodluck! |
#14 | |||
ThUmPeR
oh ok good old impulse buying. i was in jaycar and the have 6" splits for $150 forgot what RMS they were tho...:( he said best splits there is....?
#15 | ||
i think the 6" splits are about 75rms, they're up that way anyway. i am sure they are cheaper than $150
two of my mates have them! value for money you cant go wrong they are awesome! I just couldnt be bothered hiding crossovers and running tweeters ![]() |
#16 | ||
My memory must be shot! Here are the specs!!!!!!
5" Coax 30rms - $30 6" Coax 35rms - $40 5" Coax Kevlar Cone 50rms - $110 6.5" Coax Kevlar Cone 75rms - $120 6" Kevlar Splits 55rms - $140 6.5" Kevlar Splits 60rms - $150 |
#17 | |||
And they're 60wrms. |
#18 | ||
'03 BA XT
Hi guys, thanks for your posts.
I just want to say that I put 6,5" JVC splits (were on special in supercheapauto) and they're very nice. The good thing about them is that you can either screw them with 4 screws or 3 (most fords have 3 holes every 120 degrees). According to my calculations the max deph of the speaker cone shoudn't be greater than 63mm, however most of the speakers I saw were between 40-46mm deep. To put the speakers you have to unscrew door handles and the whole panel. Thanks again |
#19 | ||
[ 5L ]
does anyone know if the alpine type r 6.5 inch splits will fit into an eb door, or will they be to big and hit the window.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
#20 | |||
Ea Falcon S
sorry to change topic, but whats the size difference between speakers in a EA door compared to a ED door.....the ED's seem alot bigger??....
Jarv Smith 88' Ea Falcon S 3.9MPFI 5 speed Manual Motivator Headers with 2.1/2" RedBack system XR x GT Hybrid Body 15" 'Snowflakes' 90' GL Interior Custom Black Vinyl Roof Custom Console Lid 9" LCD + PS2 Boss CD/MP3 head unit 50x4w Quote:
#21 | ||
[ 5L ]
ea is 4" ed is 6"
#22 | ||
You win again, gravity!!!
EA's (and EB1 IIRC) have a 4" Speaker versus the EB2 - ED 6" speaker.
1966 Fairlane 500 XL
