Old 13-11-2006, 08:53 PM   #1
MADED-6
MADED.6
MADED-6's Avatar
Default clutch fan v thermos
as title says i have my motor out and when i put it back in i want to know whether to go thermos or not. i dont want to kill my battery as i heard can happen and i also dont want my car overheating when warming tyres up at drags which i heard thermos are bad for as the only come on at certain points where as clutch fan stays on most of the time and will keep air flow coming better. will thermo fans do much for responsiveness or power and fuel economy.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 08:59 PM   #2
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
wel.. ive had both....
id say go th thermos man...
1. no shitty loud *** fan noiske when ya car is cold...
2. makes a big difference to responsivness/econemy when fan is in full swing... (hot day aircon on.... or at 1st start up)
3. if thermos made ya car over heat when ya did standstills... every car on this forum from ef onwards would be dead =P lol
4. if ya battery would die... again every car from ef onwards would hav dead batteries =P
just make sure u set up the thermo switch to come on at the right temp. and ur set!
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 09:04 PM   #3
snypereb
[EBGLT]
snypereb's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Next mod on my car will be thermo's!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 09:18 PM   #4
Damo
just keep the clutch fan if the noise doesn't bother you.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 10:09 PM   #5
eb2flyz
bettering 13.7
eb2flyz's Avatar
cheers josh.
how long are you planning to sit on the skid pad for? if worried about that you could also wire in a switch to enable you to overide the thermo switch and run them.
thermo's all the way IMHO lot less drag on the motor and alot quieter.
std stroke, alloy heads, comp cam, tfs manifold, 75mm t/b, 70mm maf, 30lb inj, adj fuel press reg, twEECer
FPV/Tickford Club of W.A
Performance is Electronic
BPT Motorsport
eb2flyz is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 10:25 PM   #6
Polyal
The 'Stihl' Man
Polyal's Avatar
When I put AU thermos in my last EA it made a noticeable difference. Its way better, this discussion as be done to death but there is a definite power difference, no matter how small.
Not only that your car wont sound like a hover-craft.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 10:27 PM   #7
Psycho Chicken
Psycho Chicken's Avatar
I didn't notice any power difference on the Fairlane. But it sounds better.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 10:40 PM   #8
Polyal
The 'Stihl' Man
Polyal's Avatar
Maybe "power" isn't the right term, but it certainly feels freer; which must equate to some kind of power gain no matter how small.
Old 13-11-2006, 11:06 PM   #9
ORSMEB
Steve
ORSMEB's Avatar
I noticed no power or economy difference really. Only the noise factor. I very rarely heard the clutch fan, but now I hear this loud noise everytime I sit at the lights.
ORSMEB is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 12:41 AM   #10
Cools better in my NB and they last longer than clutch fans (average life 2 years) but in the height of summer in WA with aircon on max and all the Fairlane goodies running I do get a flat battery.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 12:52 AM   #11
DEVL-XR
EBII XR6
DEVL-XR's Avatar
thermos are on the way for my car too! as said they're not loud when you rev the motor like clutch fans!
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 12:54 AM   #12
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
they are 100% better if you set them up right.
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 12:17 PM   #13
vigilante000
/\/\etaL and V8s -Awesome
vigilante000's Avatar
Thermo's man, I have taken tooooo long to put these onto my car, and they work a treat. I have since taken the Davies Craig switch off and put a more 'factory' look switch in the thermostat housing. The car will be more responsive, considering it doesnt have to spin a spring/viscous fan, and I can tell you the temp range for them to come on is 95°C ON - 90°C OFF. This is just under half when they come on, and they go down to just above 1/4 which takes 30 seconds to acheive this.
Wiring is simple and the EF fans are very reliable. Go For It!.
Please also see my other post - EB - Thermo fan Conversion Success.
ViGiLaNtE351
Nothing Sounds Better Than A V8
BA XR8 MKII
EB Falcon ThermoFan Conversion
http://www.fordforums.com.au/showthr...t=vigilante000
BA Falcon ICC Speaker Wiring
http://www.fordforums.com.au/showthread.php?t=11342785
BA Wiper Motor in XE
http://www.fordforums.com.au/showthr...=1#post5393955
vigilante000 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 12:41 PM   #14
NC_GHIA
FirstOnRaceDay
NC_GHIA's Avatar
How much is a thermo conversion... I am looking at doing it...
And also what is the ideal temp for thermo's I would like to set it a 1/4 instead of 1/2 temp...
MY BRAND NEW RIDE
NC Fairlane GHIA
Series II
I6.
Mods. 2.5" cat back
Clarion HU
Soundstream speakers amp and subs
Lowered
DL LTD rims
: thats it!
For the moment... :
NC_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 12:52 PM   #15
OED666
OED666's Avatar
unless you are planning to pop the tyres doing a skid at the drags, you wont have any problems. if it does get hot doing a little skid, maybe your radiator is shagged, or you have cooling problems. i took the radiator out of my little brothers car on the weekend when fitting thermos, and it would have been at least 1/4 blocked with **** between the ac condensor and the radiator.
i cleaned the radiator, and got most of the **** out between the fins. also fitted a cooler thermostat. i have been driving it around with no fans at all, and its even cooler than what it was with the fans on 100% of the time.
thermos are the way to go. i never had any problems with low voltage. if your battery dies with thermos, it was on its way out anyway.
I drove Rollins car for 2 odd hours, with stereo pumping, A/C, etc on a warm December day, no dramas... with a 75amp alternator. The voltage gauge was dipping to 10v quite regularly...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 01:34 PM   #16
vigilante000
Thats what everyone does set them at mate, when they reach under half, the fans take the temp back to about 1/4. Like I said the IDEAL temp range is 95°C ON - 90°C OFF. When your driving, they will never come on, unless your towing up a hill, or you have major probs with your cooling system. My gauge stays just over 1/4 while cruising. Only just reaches under half when stopped in traffic, then fans come on, 30 secs later, all is cool - literally!.
Conversion cost less than $200
ViGiLaNtE351
BA XR8 MKII
Old 14-11-2006, 07:10 PM   #17
MADED-6
MADED.6
MADED-6's Avatar
yeah i think i will do it just that most cars other than falcons i see overheat with them as in commodore vr-vs with them all the ppl i no with them just idling through drive throughs they overheat. but yeah if u guys say they are good then i will have a crack at doing them. can anyone pick them up sheap for me or tell me a place to try.
cheers josh.
TUFAU-8
Get Stroked.
Old 14-11-2006, 07:25 PM   #18
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
yer i will be giving it ago soon
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
