Old 06-02-2007, 02:46 PM   #1
S3SR
S3SR's Avatar
Default Problem with the AU
this only happens with the aircon on
lately if i put the AC on, whenever i stick the clutch in it feels like its grinding/rubbing on something, start driving then brake to a stand still and the revs stay on 2k. turn the AC off and it falls down to 1k (idle)
with AC on and starting from stand still it makes a fairly loud metal on metal rubbing sound.
btw car is 5sp SR, serviced recently, aircon get cold quickly
any ideas??
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2007, 03:03 PM   #2
james22
With da Warlords
james22's Avatar
its not the a/c clutch is it? the bearings on my EA went, and it made the sound you are reffering to.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2007, 03:14 PM   #3
S3SR
S3SR's Avatar
the ac has a clutch???
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 06-02-2007, 03:50 PM   #4
james22
With da Warlords
james22's Avatar
yeah its called the A/C Clutch. Because when the car is running, the pulley is always turning, but your AC doesnt run 24/7.
So there is a clutch that hooks up, so that the AC can spin ON and OFF... If the bearing in the clutch are worn, it will make a heavy metalic grating noise & because the pulley is seizing, it can make the engine work far harder to turn the pulley. Had this happen a couple of time on the EA, but never with a serpentine drive belt.
Windsor Warlords
AU III XR-8220
Old 06-02-2007, 06:50 PM   #5
EvilChief
Boost Addict
have a listen under the bonnet on where the sound is coming from .. if it comes from front passanger side, it would point towards the AC clutch
if bearing is seizing, the engine would idle up more to keep it alive.
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2007, 08:35 PM   #6
S3SR
S3SR's Avatar
james thanks for clearing that up i just learnt another thing today
why does it make the actual clutch feel like its grinding as well? i was told it could be a stretched clutch cable?? i dont no
theres like a squeel coming from the front passenger side...so AC clutch??
is this bearing expensive and hard to replace?
thanks
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 07-02-2007, 08:29 AM   #7
james22
With da Warlords
james22's Avatar
I'm not sure on that one man, I can't really see how they can be related...
If your clutch cable was stretching, you would probably notice that it's a bit harder to get into gear, especially reverse?? Because your clutch wouldn't be hooking up 100%
Have a good listen in front of the pulley. If you use a screwdriver or stethoscope and place the tip of the screwdriver just behind the pulley and your ear against the handle, it should make it easier to hear.
If you hear your noise, its a safe bet the bearings are wearing & the pulley is starting to seize.
And as Evil Chief said, if the pulley starts to seize, your car will idle up, because of the extra load on the motor while running.
Never had to replace one on an AU, but with the EA it cost SFA....
Best of Luck..
James
Windsor Warlords
AU III XR-8220
Old 07-02-2007, 08:56 PM   #8
S3SR
S3SR's Avatar
whats SFA
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 07-02-2007, 09:06 PM   #9
HLC
Audi S3
whats SFA
sweet fword all
HLC is offline   Reply With Quote Multi-Quote with this Post
