Old 09-04-2007, 11:58 PM   #1
gregtomfred
Smile Clock Back light
Hi guy's,
I have an AU3 Sedan 6 cyl, Low, No climate control
that has lost the backlight to the clock.
Can some one advise me of a possible cause (Fuse/Globe??) if globe, how to remove radio surround panel that houses the clock, (assuming globe is fitted to clock.)
Thanks in advance
Gregtomfred.
gregtomfred is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 11:04 AM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
yeah, the clock uses the same bulb as the odometer.
there was a workshop article on how to change this.. don't know where though.
but it is just a standard twist in / twist out bulb. buy from ford, about $4 each or so.
Old 10-04-2007, 10:07 PM   #3
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Wow, I come on here going to post this same thread, coz mine hasn't had a light behind the clock since I got it, kept forgetting about it until I asked dad who used to own an AU3 ute whether or not its meant to be lit and he told me it was.
Interested to know how to change the globe once I've got my hands on one, will have a bit of a search around the forum/site.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 10:14 AM   #4
gregtomfred
Rikstam
When you find out how please post.
I realise that I need to remove the radio, and also need to make 2 wire tools to do this, BUT BUGGER me if I can get the radio to slide out, ran out of time, so put it on the back burner for nowm but still would like a light in the clock, and I am not going to pay Ford's exorbinet charges to do it.
The globe is available from Ford ($4-5, small twist & fit?)
Old 15-04-2007, 05:51 PM   #5
jman
My glock globe is also out on my 98 EL futura, would be interested to know if its the same procedure to replace as an AU or not..
jman is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2007, 06:00 PM   #6
swanee
spoolin!
swanee's Avatar
With your EL. The best way to change the globe is like this.
Take a small screwdriver and remove the rear demister switch bezel by prying it gently loose.
With the bezel loose, reach in and push the clock forward so it comes out. the globe is a twist out type and is best removed with needle nose pliers.
The globe is about $5-$12... depending on the globe that is in it.
swanee is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2007, 07:39 PM   #7
stats2001
amazing...me too, I have had no light behind my clock either since picking up the car abt 6 mths ago...Never got around to fixing, so maybe this will give me the incentive...
Thanks for the reminder...
Mark
stats2001 is offline   Reply With Quote Multi-Quote with this Post
