Old 10-05-2007, 10:13 PM   #1
02auxr8
Default AU XR8 VCT miss firing
The car is a 2002 au series 3 xr8 VCT. Fine at idle but seams to miss fire when i am driving. Any ideas. Just changed leads and plugs and double checked connections. would a diagnostic self test give me any hints and if so how can i do one?
02auxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2007, 10:18 PM   #2
Casper
Contributing Member
Casper's Avatar
XR8 or XR6VCT?
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2007, 10:37 PM   #3
b2tf
not here much anymore
b2tf's Avatar
how many kms, any mods done etc
2024 F150 XLT
Old 10-05-2007, 11:05 PM   #4
paddle
paddle's Avatar
Wink
Originally Posted by Casper
XR8 or XR6VCT?
Guide dog Casper?? LOL!!
paddle is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2007, 11:09 PM   #5
Casper
Contributing Member
Casper's Avatar
I'd love to see a Variable Cam Timing AU XR8... it would be an astounding feat of technology on a Windsor.
Old 10-05-2007, 11:47 PM   #6
FGII-XR6
FGII-XR6's Avatar
i'll have one thanks
Old 11-05-2007, 12:09 AM   #7
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
I wouldnt mind one for my series 3. I must have been sleeping when they released that motor
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2007, 12:12 PM   #8
02auxr8
Default mods
It has pacemaker extractors and a 3inch stainless steel exhaust. SS induction system.
Old 11-05-2007, 12:13 PM   #9
Sapper
Back to the AU
Sapper's Avatar
I suppose you also missed the XR8TT (Twin Turbo) realeased as a limited edition along with the XR6ST (SuperTurbo). Sleep is bad man.... :
02auxr8, I'm guessing your car is an XR8 right? In which case it doesn't have VCT. The only Falcon V8 to have VCT (that I'm aware of) is the SOHC 5.4 Boss. Reason for confusion is there is an XR6 VCT. Its easy to accidentally hit a 6 instead of an 8.
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU
2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth
Sapper is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2007, 12:28 PM   #10
JC
JC's Avatar
Actually, the XR6 ST is an actual model, and it stands for SprinT, not SuperTurbo. Lack of research is bad man.... : LOL.
Mods: Tune, ShockWorks, GTE 19” - 8” & 9” with 245 & 275/35/19 Michelin Pilot sport 5s
Daily: SZ Territory RWD 6R80, 20 x 8.5” rims 19” with 245s and Gabriel shocks & SSL King springs
Ford Performance Club ACT
Old 11-05-2007, 12:30 PM   #11
Sapper
Back to the AU
Sapper's Avatar
I know, I own an XR6 ST (comment was part of the joke). Hence the ST is Naturally Aspirated.
Old 11-05-2007, 02:46 PM   #12
02auxr8
Sorry remove the vct remark-its my brothers car, just posting for him as he does not have the net. it is the 2002 series 3 au xr8. So can you help at all.
Old 11-05-2007, 02:51 PM   #13
Sledgehammer
Sledgehammer's Avatar
Looks like you have checked the usual suspects, (plugs, leads, loose conections to coil pack), what about a faulty coil pack , dirty injectors, what about the alternator pumping out the correct voltage.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2007, 03:03 PM   #14
02auxr8
Going to go through those on saturday. Thanks. any other thoughts and any idea on the computer self test.... i know on some other cars i have owned you could use a multimeter or even a led to get a sequence code out of it... Or have they done the typical where you need a special tool or diagnostic unit. Or would this be a waste of time on the type of problems i am having.
Old 11-05-2007, 07:25 PM   #15
Cobra
Bear with a sore head
Cobra's Avatar
Theres two integral parts to an engines operation that critical in making it run right. You cant have one without the others, and you need both working in sync or you'll get a rough, or worse, no idle as she wont go. Fuel and spark are those two things.
It sounds like you've covered most of one side, short of a coil or some other electical problem, I think you have a problem on the fuel side. I would be starting with checking fuel pressure. I would also check that the injectors aren't clogged up. If you find that the fuel is stail, it's most likely the whole system will need a flush including replacing a fuel filter.
Cobra is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2007, 09:27 PM   #16
V8falcons
V8falcons's Avatar
Mate change the fuel filter
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2007, 11:19 PM   #17
howesy
howesy's Avatar
When you say misfire is it missing or is it a backfire from inlet. backfire check for air leakage between MAF and throttle body
Missing can also be caused by a weak or broken valve spring which performs at idle but not above. When its a mechanical issue it usually takes out the cylinder diagonally opposite on the coil pack and you should have coil pack fault codes registered on the ECU.
Of course this is on the outside but not uncommon but check all the other possibilities first,
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2007, 11:26 PM   #18
RG
Back to Le Frenchy
RG's Avatar
I'd say coil pack. A test on it would only cost you $20 from a decent mechanic. If it does turn out to be one make sure you replace both but don't get them from Ford.
