acclaimed user
As per the topic title, I'm doing a BA brake conversion onto my series 1 AU. is there much advantage doing the rears as well? are the pads much bigger on BA's?
im lookn at doing the same and it looks like BF/XR & BF FAIRMONTGHIA have a bigger rear pad in them otherwise all au's and ba's etc run the same pad...thats lookn at the bendix web site
http://www.bendix.com.au/ProductCatalogue.aspx |
If You Are Upgrading Front Disks On A Series 1 Would Like To Know How The Front Was Done . I Have Heard It Can Be Difficult Unless You Have A Series 3
Commercial Sponsor
the BF XR8 and territory use a big 328mm ventilated rotor.
They will fit onto a AU but you will need to space the caliper out with a washer for it all to fit up. we have sold a few of these kits now and also fitted them up to our wagon we built early this year |
so sedan calipers and rotors will fit on a wgn yeah with a spacer..does your kits come with spacers??
#6 | |||
Commercial Sponsor
A lot of people have stuffed around with trying to copy our kits, to save only a few dollars. we have put the time into working out these kits so you dont have any down time. you just bolt it on and off you go. |
#7 | |||
acclaimed user
Thanks for the info, it seems there is no point getting the BA rears |
#8 | |||
Commercial Sponsor
it is worth the hassle to put the BF XR ones on as they are huge! |
