Old 07-03-2008, 02:04 AM   #1
Chamelion
Default Trim set on ebay...
Hi all,
I was considering purchasing this CLICKME.
Are they reasonable? Dodgy? Worth it?
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2008, 02:13 AM   #2
TwistedEL
TwistedEL's Avatar
NOTE: These dash kits are not replacement parts for existing dash components. They are made from a self adhesive UV protective synthetic resin material that is fitted over the top of the existing dash. The dash surface should be thoroughly cleaned before installation and free from any Armour All or other additives.
Stand out from the crowd and make your Falcon AU Series 2 look
They are stickers. I wouldn't do it. The fairmont came with brushed alloy look gear surround and I ditched it in favour of the series 1 chrome item.
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2008, 11:06 AM   #3
aye you
The Origional, The Best
aye you's Avatar
yep, you may get 6 months out of it then it'll start peeling because there was a minute bit of armour all on it, or you/someone will scratch it and it start to lift. just not worth it to he honest
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2008, 09:28 PM   #4
HOTC2R
Has anyone actually seen these in real life. Because if you have, you would know that these aren't just cheap crap stickers.
I have the woodgrain one in my wifes AU which has been in there for the past 3 years and there is no peeling yet.
It is supplied with a small bottle of turps / alcohol to clean the surface before hand and if memory serves, uses one of the 3M sticky adhesives, which is very strong.
This is a 5 piece set which was the lesser of the 2 kits, but the main pieces are there. The other kits had about 11 pieces but it was smaller pieces like ash tray cover and a piece either side. One piece where the clock is etc.
I have dealt with this company on a couple of occasions and am very happy with them.
You will need to use furnisher cleaner like Mr Sheen etc to clean it as armour all get underneath it, yes it will peel, as it is designed to get under sticky things to clean.
HOTC2R is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2008, 09:50 PM   #5
Chamelion
Looks like I missed out anyway. :(
Old 07-03-2008, 10:09 PM   #6
private9
www.TUFFCARPARTS.com
private9's Avatar
Hey mate, how do you find the colour match of the woodgrain compared to factory stuff?
I'm putting a Fairlane interior in, and seriously cannot be stuffed doing the dash, so I figure this'll be a nice way to tie the pov pack dash in with the Fairlane woodgrain door trims etc.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2008, 02:24 PM   #7
HOTC2R
I was suprised when I went to burgedesign to have a look at it, how good it looked.
I could be wrong but don't you live around cheltenham. Burgedesign are in Moorabin.
Old 09-03-2008, 10:33 AM   #8
AUIII
AUIII's Avatar
I just brought the woodgrain trim set , I have ghia door trims and like you could not be bothered changing the dash, I will let you know how good it matches when i get it.
Current Ride 2012 Mitsubishi Triton Dual Cab ute :
AUIII is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2008, 01:56 PM   #9
Chamelion
I've emailed asking if they have any more available.. Here's hoping.
Old 10-03-2008, 10:48 PM   #10
private9
private9's Avatar
Yep, just around there, so I'm gonna have a look, thanks!
Old 10-03-2008, 10:48 PM   #11
private9
private9's Avatar
Thanks mate, that would be awesome!
Old 11-03-2008, 12:16 AM   #12
Chamelion
Still no reply on whether they have any more brushed alloy sets :(
Old 11-03-2008, 04:04 PM   #13
Chamelion
They listed another one, but ouch.. I only just noticed how much they're expecting to post it. I just can't spend that much on an interior improvement right now. :(
Old 11-03-2008, 04:57 PM   #14
sly
Sly like a G6
sly's Avatar
I couldn't resist the woodgrain replacement console for the AU1. Hope it fits better than the original!
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
