[ 5L ]
for a while now my car has had a clunk when turning corners at low speeds, i though it might be the diff or the tailshaft but i read up on the forum about it and im fairly sure now it is my rear shock mounts.
i went out this morning and came across this drivers side im guessing this is a little worn but generally what they are suppose to look like. ![]() passenger side, this one has collapsed alot and it actually resting on the body of the car. ![]() to fix these do you just drop the shocks put the new shock rubber mounts in and put the shocks back up? how much roughly would it be to get this fixed?
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
[ 5L ]
also do you know if this could also be the problem for my diff bounce. it sounds like the diff is hitting the floor, maybe its the shock hitting the mount.
The diff cant hit the floor as its mounted in the cradle and doesnt move, the drive shafts move up and down though, so does the rear struts so looking at your pics, it will definatly be the strut hitting.
[ 5L ]
no worries cheers
they look upside down mate??
the metal "washer" type bits anyway.. can anybody confirm??
[ 5L ]
well its all standard, suspension has never been worked on. unless ford messed up.
#7 | |||
[ 5L ]
ah ok fair enough so someone has messed up along the lines.
[ 5L ]
can anyone get a pic of there so i can compare
well they would be removed to change shocks so presumably thats when its been played with...
which is why they have sort of cut into your rubber surround mate the busted ones usually just move up and down not like that.. they are pretty cheap to replace if you fit them your self good luck
[ 5L ]
no worries cheers, so basically that washer/cup thing just gets turned around the other way.
[ 5L ]
so can anyone give me a simple write up on how to do the job.
i was thinking that the shocks would need to get dropped, and then the rubber fitted.
#13 | ||
for the rears.. undo the 4 nuts on the top there in the photo
and the bottom shock bolt and from memory theres 1 other bolt you need to undo to remove them i just cant for the life of me remember which one.. 2 people is alot easier too good luck mate
#14 | ||
[ 5L ]
ah ok so the whole shocks need to be taken out for the job
#15 | ||
yep
$90ea approx from ford for a replacment upper strut mount the top piece is 2 halfs.. 1 is the spring seat which slides into the bit you see there just bang it on the ground a few times or get a mate to pull the halfs apart and then just slide new one on and re install
#16 | ||
[ 5L ]
no worries cheers.
