14.915 @ 151 KPH
as the tittle say's i took some crap out of the car and the best run was a 14.915 @ 151 kph which is bloody quick i reakon!! so for those of you who think that weight doesnt do much think again !! thats 0.4 seconds plus 4 kph quicker than full street trim (15.3 @ 147 kph)
:evil3: 96 EF2 Futura I6 Auto :evil3: EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's ![]() ![]() ![]() |
Damn thats quick well done dude
What Wheelspin?
your 60ft is a bit crappy. need to practise them launches.
good time none the less.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
B E-S
Backseat weights all, not sure why you bothered with that part?
14s for an auto's a pretty good time though.
B E-S |
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
lol weight does matter BUT each 100kgs you remove is equivilent to 0.1 of a second
So to obtain 0.4 seconds quicker you would have to remove 400kgs So many variables go into what happens on the 1/4 mile, weather, track, tyres, tune, gear change, etc etc Removing weight helped but there was something else that helped you get 0.4 quicker......... Good time none the less ![]()
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
Factor in reaction time and the biggest problem most novices have is the traps at the finish line where by once they hit that they take the foot of the pedal therefore registering a lesser ET&MPH than they in fact have run. Remember that the way to work out best ET for bracket racing is to run it it clearly through the back door and then work from there there as to what you nomionate in the effort too gain best staging options in DYO brackets,
#7 | |||
What Wheelspin?
100kg's = .1 of a sec? thats not true. that doesnt take into account tourqe etc. do u think that if u added 100kgs into an 1983 laser it would only affect it by .1 of a sec? ive heard that rule so many times. i weigh 100kg's. and have a mate who weighs the same. with both of us in the car, it is slower than only .1 of a sec. TRUST ME.
#8 | |||
Worked in my Charger – but I guess my Charger NA 6cyl pulls 13.3 and I am talking about a performance car LOL
What Wheelspin?
was using it as an example. thats how the laser came up. how did it work in your charger? did u actaully try adding 200kg's? u would loose WAY more than .2 of a sec down a 1/4mile with an extra 200kg's. thats 4 bags of 50kg cement in the boot! and like i said, depending on car and power, it would change heaps.
MADED.6
yeah id have to agree with mr 4.0 with this, sorted 13.3 isnt a massive performance car but is good for an n/a 6.
next time anyone goes to the drags take a mate in the car and try it again i recon itd drop .2 or so of a second. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
#11 | |||
14.915 @ 151 KPH
#12 | |||
14.915 @ 151 KPH
#13 | ||
![]() Join Date: Jan 2005
Unless you have a chip or flash tuner, the 98 RON had nothing to do with the time.
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, ShockWorks, GTE 19” - 8” & 9” with 245 & 275/35/19 Michelin Pilot sport 5s Daily: SZ Territory RWD 6R80, 20 x 8.5” rims 19” with 245s and Gabriel shocks & SSL King springs FPV 335 build stats: <click here> Ford Performance Club ACT |
#14 | |||
14.915 @ 151 KPH
#15 | ||
Yh i belive that too, try explaining how my car runs sweet as on shell 98 yet any other servo 98 causes it to ping hm...
You got your self a freak there mate good job on that time. Brad |
#16 | ||
A couple of links for you to have a look at
this one is an ea http://www.fordforums.com.au/showthread.php?t=11222462 and this one is of all those that have graced aff with their time in an eseries http://www.fordforums.com.au/showthread.php?t=21392 also not to bad a time either there is one missing from the list there that is where i want my el to be at and that is a car known by evil ran a high13s 1/4 with an auto i have the cam out of evilin my el also running the ecu out of it as well since i done those changes i have not run it on the 1/4 ( with the head i have on it ) Jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
#17 | ||
What Wheelspin?
silent raptor, what car do u have?
#18 | |||
14.915 @ 151 KPH
#19 | |||
14.915 @ 151 KPH
#20 | |||
ran a 15.42 with same set up but with a 977b in it since that i have put a better head on and running the cam that trick-xd ran a 13.77 with an auto in his el on gas ( mine will be on gas before it runs again ) i have also added a 3.7 lsd to the fun (he was running a 4.11 spooled dif ) and i am not running the J3 chip atm your time was good but as others have said it will get better with a better 60ft time Jason
#21 | |||
14.915 @ 151 KPH
#22 | ||
What Wheelspin?
SOME cars can double their gain to 60ft at the end of the track. i say SOME.
if u knock .1 off your 60ft, you could gain up to .2 at the end. .1 doesnt sound like much, but making a car launch harder, without wheelspin, and consistant is very hard. so .1 is a good gain. if i was you, id practise my launches, get GOOD tyres, and try get your 60ft down to 2.05secs. with a cam and tune you could see a 14.6. but no quicker without high stall.
#23 | |||
14.915 @ 151 KPH
my plan is to get a low 14 without major work, i think my car has it considering the times it runs with no internal work. i will be happy though if i can get it under 14.5, thats quick enough to scare most new car's! i said scare not beat lol ![]()
#24 | |||
#25 | |||
JMM modded EF
My brothers ef futura manual with a bruce heinrich cam, diff, tune, intake, exhaust used to run consistent mid-low 14s.
"She goes like a zirtek" WANT A FAST FORD RING THIS BLOKE V V Abbott Engines for HeadWork 20 years experience PH Rob on (07) 5526 3883
