05-05-2014, 02:31 PM | #1 | ||
Hey All,
Friend of mine has a series 2 Au Xr6 Vct, And when ever the car is running you can hear air leaking quite Loudly also runs very sluggish since this air problem has started someone suggested replace the small plastic F piece under the throttle body done that and still no good its around under the throttle body area you can hear it, Any help is greatly appreciated. |
06-05-2014, 08:23 PM | #2 | ||
5.6L x 2 pilot
My only suggestion would be to use about a meter of garden hose or similar with one end at your ear and the other end searching the engine bay to attempt to find the source of the noise. Search around all of the vacuum lines around the intake manifold and hopefully you will find the source of the leak.
Good luck with it. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
07-05-2014, 11:55 AM | #3 | ||
Au Falcon = Mr Reliable
Check & tighten your intake manifold bolts, you may find some loose?
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
07-05-2014, 07:29 PM | #4 | |||
it will idle terribly as well....
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
