Fantastic Plastic
Hi guys , Just wondering if anyone knows of a model B&M quick shifter than will match the auII xr6 auto and even if a bit of DIY needed to make it fit the console is np ( so long as the souround for the auto's base is at least a tadd larger than the original) as i want it too look clean and no gaps etc etc.
I originally had a B&M megashifter hooked up in my XE to my Ford Fiad/Fiod (AOD pattern) 4speed auto when thay first come out nearlly 15 years ago. They were a great shifter, I loved the ratched effect where the shifter position was allways in the same position no matter weather you was in 1st,2nd,3rd or 4th - awesome - never sliped or missed a gear. I'de really love one in my AU thats for sure ! , any help would be greatlly appreaciated, I've checked the B&M website but i can't seem to find anything to fit in the au's/xr's ... help plzzzzzz ???????????????? lol .... ???
i wouldn't mind one also
Audi S3
what are they exactly :|
Fantastic Plastic
Even if someone has the specs & name of the automatic transmission in the auII xr6 vct (it's the adaptive shift tranny) ???????? , if i can get at least these details then i might be able to work out something compatible ... cheers , any help appreciated ?????
Fantastic Plastic
have a look at them , http://www.bmracing.com/index.php?id=products , check out the automatic shifters / quick shifters.
They arent made to suit the au 4 speed but may be able to modded to suit. I think they only suit hydraulic boxes which the ford boxes arent.
They would have no benefit other than looking cool in an EA onwards ford.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#7 | |||
Fantastic Plastic
Fantastic Plastic
oh , and yeah the old Ford fiad/fiod 4 speed auto was a hydraulic box ! , was originally out of a mustang from the usa the tranny i had.
Fantastic Plastic
Just to mention , they are an older tranny nower days but they were strong as hell , never gave me any problems and bolted straight up to the cleveland v8 np, the auto use the bar push methos , ( not a cable ) - to get it to change gears correctlly in drive too the bar had to be hooked directelly to the throttle arm on the carby ( no slack - same push on the bar according to amount of throttle given ) - within the first year of owning that tranny (and it was new in those days to anyway) , no-one knew nothing about 4 speed autos , i had it to every transmission place under the sun and no-one could set it right , it used to slip from 1'st to 2'nd (didnt jump into next gear ) - the end of that year ii nearlly sold the tranny then thought bugger it ill have a go myself , and found the right setting for the bar to the carby - problem solved, and was sweet from then on
I'm pretty sure the Megashifter can be used on a 4 speed transmission. I know it can be used on two and three speed, you add/remove screws to lock out/open gates and change the PRND21 window with the supplied spares.
Your main issue will be making a bracket for the shifter cable to operate the BTR linkage, and the big hole in the trans tunnel will need covering. I've had a Megashifter in a previous car and it was a great shifter.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
![]() Join Date: Dec 2004
The AU Auto changes gears electronically, whats the point of having a quick shifter?
May as well just remover the shifter all together and have buttons on the dash or steering wheel..
#12 | |||
Fantastic Plastic
Aaaaahhhhhh , ty ! - This is a reason why i wanted to know what tranny is in the auII xr6's (with adaptive shift). I was thinking maybe some park was going to be electronic because of the 3 shift modes selectable from 1st, 2nd and 3rd , but i didnt realize the whole tranny was electronic ! .. thanks ![]()
#13 | ||
What you are after is the same as what the T series cars have. Gear selection via buttons on the steering wheel.
One of the members on here is currently creating a conversion kit for AU's to allow this to be fitted to current cars. JC put me onto him and we are all now waiting patiently for him to perfect the conversion.
#14 | ||
Fantastic Plastic
excellent , couldn't be too hard to convert if its in the T-series anyway , might look into this myself then too , thanks ;) .
#15 | ||
Fantastic Plastic
even better , just found this thread http://www.fordforums.com.au/showthread.php?t=7564
#16 | |||
Fantastic Plastic
#17 | |||
So, I was mearly posting that a B&M shifter could be fitted, and connected, and work like the current shifter, with one plus- you can't skip a gear and you can't miss Drive and hit Neutral when shifting through the gates.
#18 | |||
Fantastic Plastic
#19 | |||
![]() Join Date: Jan 2005
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, ShockWorks, GTE 19” - 8” & 9” with 245 & 275/35/19 Michelin Pilot sport 5s Daily: SZ Territory RWD 6R80, 20 x 8.5” rims 19” with 245s and Gabriel shocks & SSL King springs FPV 335 build stats: <click here> Ford Performance Club ACT |
#20 | ||
XR6-VCT-2000, you missed this thread on the BA shifter into an AU:
http://www.fordforums.com.au/showthread.php?t=29346
#21 | ||
Fantastic Plastic
