Old 10-03-2006, 10:09 PM   #1
gthofan
Gunna girlie-man
gthofan's Avatar
Default Pod or panel filter
hey guys, just a quick question, which is better, a K&N pod filter, shielded from the engine heat, or a K&n panel filter for my airbox, with an xh snorkel. which will give me the best performance as both are around the same price.
cheers
scott
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2006, 12:29 AM   #2
302 Fairmont
6 of one, half a dozen of the other, i prolly go the pannel, it would sit neater in your engine bay ie nicely in the box. I would only use a pod if its tucked inside ur 1/4 pannel of course then u run the risk of water. I have a pod on my turbo starlet but its hangin off the turbo. In your case i cant imagine u would get any gains outta a pod.
302 Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2006, 12:38 AM   #3
gthofan
Gunna girlie-man
gthofan's Avatar
hey, thanks for ur help mate, there would be too much buggering around installing a pod anyway
Old 11-03-2006, 02:05 PM   #4
hornet
hornet's Avatar
Stick to the panel.
Member of anti-pod.
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2006, 04:16 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
Wouldnt be that much buggering around putting the pod in mate!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2006, 12:02 AM   #6
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
yeh its nothing to put a pod in.
i did the panel though. breathes a bit easier. dont expect anything too exciting tho lol.
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 04:23 PM   #7
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
are there any gains from a k&n panel filter tho? besides it being washable.
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 07:36 PM   #8
jpiez
i got a pod on mine in the 1/4 panel near my front left tyre n dont suck any water.. makes a loud sucking noise n did help with the performance down low.
95 EF, genuine tickford bodykit, sunroof, 5 Speed, Lock Rite LOKKA, Hi-Tech stainless steel extractors, hi-flow cat, 2.5 inch mandrel exhaust, extreme heavy duty cushioned button clutch, JMM port n polished head, JMM cam, raised compression, 19's, low, dark tint, microtech MTX-8 ecu, bosch 440cc injectors, clarion 7inch touch screen, 2 clarion 12inch subs, clarion 6inch 3ways, clarion 6inch 2 way components, 2 clarion amps
jpiez is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 08:09 PM   #9
snypereb
[EBGLT]
snypereb's Avatar
Got a pic of it?
[EBGLT]
