Hi Franco
Did the screwdriver test against manifold but definitely no spark. The distributor I have has a seven pin plug and although I replaced it I did place it back into the car the same way however the fault did not change after replacing it. I can see that there is a "knock control" bolted near the air cleaner under the bonnet which has a five pin plug attached to a 40 x 40 x 15ml small black box. Unfortunately I've no luck uploading any photos for you to view. |
