#31 | ||
AUII Fairmont Ghia
Quote == Are your tyres going ok BTW?
Fine so far bought them off DDarby but I'm grandpa driver ( 16 so far 3 more on way)
AuII Fairmont Ghia, Black leather, LPG, King lows I aint as good as I once was, but I'm as good once as I ever was. ![]() |
#32 | ||
GK
I have had similar issues on many occasions on several different cars always just after fitting new tyres and have managed to solve every problem by getting either a fine balance or on a couple of occasions on car balancing A specialist alignment & balance shop like the Dynamic alignment center in nunawading do on car wheel balancing or Beaurepaires in Doncaster or Bob Jane in Box Hill do fine or finger balancing and tighten the wheel nuts by hand with a torque stick which all helps These 3 places have solved all my vibration problems in recent years even when it was suggested that I had buckled rims and warped discs by other tyre shops Also try posting searching in tyre technical Turbo Nick and a couple of others are wizards at all tyre & balance issues Good Luck Cheers Aoutocade |
#33 | ||
oops
Repost with correction meant Donellans Box Hill not Bob Jane Cheers Autocade |
#34 | ||
Walking with God
Got the discs machined this morning and all is good. The front left was particularly bad, needed a couple of goes on the lathe! At least 1mm was taken off.
Here's the thing I've been thinking about though! The instructions with the Bendix pads said to do a number of hardish brake applications, which IMO isn't very compatible with the gentle process of bedding in recommended on the last lot of rotors (the ones I installed yesterday). I asked the Brakes Plus guy about it and he said to always go the gentle approach to bed them in. I wonder if the harder approach I used (as per pad instructions) actually was the beginning of warping the fronts? What are your thoughts everyone? GK
#35 | |||
Fantastic Plastic
Strange the bendix say bed them in hard ?, i've never heard of bedding brake pads in hard ... although if they're a heavy duty pad , then their reason being could be to stop the pad glazing and causing squeels.... It's Strange instructions, i usually bed harder material brakes ( brake hard ) to get rid of any squeel after bedding them in soft ( if these is any squeel ). Does it say anywhere on the brake pad packaging not to bed them in hard on 'new' rotors/discs ?
#36 | |||
![]() Join Date: Jan 2005
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, ShockWorks, GTE 19” - 8” & 9” with 245 & 275/35/19 Michelin Pilot sport 5s Daily: SZ Territory RWD 6R80, 20 x 8.5” rims 19” with 245s and Gabriel shocks & SSL King springs FPV 335 build stats: <click here> Ford Performance Club ACT |
#37 | |||
Walking with God
GK
