Old 28-06-2007, 10:24 PM   #1
Falcon4L
'04 BA XT
Falcon4L's Avatar
Default Fix for whistling?
Hi I have just installed an aftermarket DVD player into my BA falcon but can't get the whistling noise that seems to be caused by an earthing problem to go away. (It whistles louder depending on throttle and RPM's if that helps describing the problem) Do you make something to eliminate this noise as it is rather annoying?
Cheers Toby
1979 F350 Tow Truck
80 series Turbo Diesel Cruiser
Falcon4L is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2007, 08:42 AM   #2
FADI75
Sponsor
Cheers Toby
toby
the only thing we can suggest, its to add noise suppresors/filters that might help.
cheers
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2007, 05:12 PM   #3
BAWagonWheels
BAWagonWheels's Avatar
As fadi mentioned, either to fit in a noise suppressors/filter. Or another thing is to check the earthing of your aftermarket headunit. Earthing must be the shortest cable to chassis you can get and make sure you have sufficient (bare metal) chassis exposed to the bolt point of your headunit earth cable. Bolting the cable onto painted chassis won't help.
I had the awful whining noise which I fixed up last week. The noise was eliminated using the above procedure which was advised by my workmate.
BAWagonWheels is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 08:47 PM   #4
Falcon4L
'04 BA XT
Falcon4L's Avatar
Thanks for that guys.. I thought that a better earth would be achieved by earthing as close to the battery as possible to eliminate the resistance of the chassis, which would be higher than some 1.5mm earthing cable
1979 F350 Tow Truck
Old 30-06-2007, 09:18 PM   #5
DOC
DOC's Avatar
Took it to Ultra tune, Havn't heard a single whistle since.
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2007, 01:50 PM   #6
genebaby
Abuser of Charvels
genebaby's Avatar
Where did you ground your car to?
Contraband Facebook
Daily: Tornado MY20 GTI
Retired: Venom BA XR8 - build thread
genebaby is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2007, 02:38 PM   #7
BAWagonWheels
i had mined bolted to the chassis behind the lining of the drivers kick panel with a bolt & star washer. the lead was soldered to the eyelet washer. be sure the power & earth wire are both the same gauge size (for my setup i used 8 gauge wires).
Old 02-07-2007, 03:08 PM   #8
genebaby
Abuser of Charvels
genebaby's Avatar
Ok, thanx.
Contraband Facebook
Old 29-07-2007, 12:08 AM   #9
Bdazla
Bdazla's Avatar
what did ultra tune do to remove the whining noise?
Bdazla is offline   Reply With Quote Multi-Quote with this Post
