Old 21-09-2007, 01:01 PM   #1
Stav
Smile
Stav's Avatar
Default Dyno sheet and air fuel ratios ...
Guys these are the air fuel ratios my car had on the dyno day recently.This is the exact state of tune which my car ran a 14.527. It is worse than a stock rich tune. What do you think the potential gain is from a decent tune? I am thinking another 10 to 20 rwkws...
http://www.fordforums.com.au/attachm...chmentid=35296
Old 21-09-2007, 02:33 PM   #2
ratter
ratter's Avatar
You will gain a little power by leaning it out, but not as much as you list, timing is where you will get your power from
Pit Lane Performance
Old 21-09-2007, 07:09 PM   #3
Stav
Smile
Stav's Avatar
I think you are pretty right mate. I do remember seeing an e series car with similar af ratios.They adjusted it with an adjustable regulator and their power did go from 179 horsepower to 197 hp.I believe it was Rollin from memory.
Old 21-09-2007, 07:41 PM   #4
sprjenkins
Spr Jenkins
sprjenkins's Avatar
nice cold intake temp too colder than the external temp
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands"
-Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times
-Chuck Norris doesn't sleep. He waits.
-Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain.
sprjenkins is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2007, 08:16 PM   #5
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Thats how it SHOULD be ................
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2007, 01:40 AM   #6
Stav
Smile
Stav's Avatar
I am not sure whos dyno sheet this is but I have kept it because their story was interesting.If it is rollins and he wants me to remove it them let me know.This is the gain from regulator pressure change only .
Old 22-09-2007, 11:08 AM   #7
daz_
Holy crap please tell me the afr's aren't that bad standard!?!?
10.5 through the midrange? THIS MIGHT EXPLAIN SOMETHING?
daz_ is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2007, 11:59 AM   #8
xr8ute
Back on the road
xr8ute's Avatar
Agreed, I was going to make the same comment.
Stav, what was your fuel rail pressure when it was last tuned? That that is really the fuel rail pressure you should keep it at.
If you need to run a higher fuel rail pressure becuase your injectors are maxing out, then set the rail pressure (say 50-60psi w/vac disconnected), and take it back to your tuner so they can at least adjust the injector slopes to compensate.
It would be better just to fit bigger injectors though, and run them at the fuel pressure they are designed for.
As for how much more power it makes? Only time will tell, but I wouldn't be betting on 20rwkw.... ;)
Old 22-09-2007, 02:27 PM   #9
Stav
Smile
Stav's Avatar
Car was tuned at 45 psi and stayed 45 psi mate.The standard injectors were removed as they maxxed out.I ran out of fuel at 120kmph and 166rwks I am running bigger injectors.Everything is the same as tune day but the pump which failed has been replaced.
Old 22-09-2007, 02:34 PM   #10
xr8ute
Back on the road
xr8ute's Avatar
OK. So the tune hasn't been touched since the bigger injectors where added?
What part number injectors are you running?
Old 22-09-2007, 05:50 PM   #11
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
with a colder intake temp then ambient, the power result will be wrong anyway. thats a bad dyno operator that did that!
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2007, 07:01 PM   #12
Stav
Smile
Stav's Avatar
I dont know about the temp differences. Should the result been less? Not that the numbers mean much but the air fuel ratios will need fixing. I will get them fixed soon. The full potential of the car is what I am after.If the figures look good then thats a bonus.It may even be a dead map sensor.
Old 22-09-2007, 09:40 PM   #13
xr8ute
Back on the road
xr8ute's Avatar
You've changed to bigger injectors, but haven't mentioned having it re-tuned for them?
I wouldn't be too worried about a 2 degree difference in the measured ambient and intake temps on your dyno sheet....lol.
EDIT: just saw your other thread where you mentioned you had another tune after the injectors where fitted.
At what fuel pressure are those injectors rated at 29lb/hr? What brand and part number are those injectors?
