Old 21-12-2012, 10:26 AM   #1
COLLINSMARK
Default Re: 2.0 LT Focus Engine warning light
The engine warning light has come on. The car hesitates under acceleration. It seemed to begin after mistakenly putting a couple of litres of 5% ethanol fuel in. Any ideas?
COLLINSMARK is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2012, 11:10 AM   #2
Russ
Russ's Avatar
I wouldn't have thought 5% would bother it too much, maybe a crappy lot of fuel, did you buy it from the usual place you fill up at ? Maybe give them a call and see if any others have been complaining of issues :( If all else fails try disconnecting the negative battery terminal and leaving it off for a half hour or so, then reconnect and take it for a drive for 15 mins or so, this will reset the ECU (PCM) Hopefully this will help
Old 21-12-2012, 12:02 PM   #3
COLLINSMARK
Thanks. I didn't get fuel from normal place.
You'll hear from me, good news or bad.
Old 21-12-2012, 12:21 PM   #4
Russ
Russ's Avatar
Best of luck with it
Old 21-12-2012, 10:43 PM   #5
COLLINSMARK
I did the battery off thing. All seemed well at first (the light was still on), but after stopping for a while, the hesitancy returned though not as bad.
Old 21-12-2012, 11:26 PM   #6
Russ
Russ's Avatar
You're probably going to need to have a diagnostics check done on it to see if it throws up any error codes, it may just have been the fuel causing the engine light to come on and it might need to be reset. Hopefully it will improve when you refuel but I would suggest not running it on anything less than 95 RON if at all possible.
Old 22-12-2012, 09:34 AM   #7
COLLINSMARK
Yeah, always 95. What do you reckon to spark plugs? They're 185ks old. (yep, I do a lot of ks!)
Old 22-12-2012, 11:02 AM   #8
Russ
Russ's Avatar
It sounds like it needs a real good service if the plugs haven't been replaced after that many k's You might want to consider replacing the leads as well at the same time, I would still be having the engine light issue checked first because it may be something else causing the problem, such as a failed oxygen sensor. It would obviously make more sense to try and diagnose the problem before replacing parts unnecessarily, even though the plugs and leads will most likely need doing anyway
Old 22-12-2012, 12:35 PM   #9
COLLINSMARK
Ok. Thanks, a job for tomorrow.
Old 22-12-2012, 12:38 PM   #10
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
Seen this problem when the cat fails
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2012, 02:09 AM   #11
DZFord
DZFord's Avatar
The 2L engine doesn't have spark leads. It's a coil on plug ignition system. Still wouldn't hurt replacing the plugs anyway since you've done so many km.
You should read the code via an OBD II scanner, which will give you the exact fault. Also, you will be able to reset the child engine light once the fault is fixed.
Old 23-12-2012, 07:55 PM   #12
COLLINSMARK
Tried to remove a coil retaining bolt but it wouldn't budge. What do they use to fit them at the factory!!! Have to get my small socket set from work.
Old 23-12-2012, 08:20 PM   #13
COLLINSMARK
What's a cat worth? DIY or shop?
