Old 13-03-2016, 09:25 AM   #1
rondeo
Default DTCs
2007-2014 Mondeo
List of DCTs set by decision of GEM (under glovebox), most of which come via MSCAN bus? B=Body,C=Chassis,P=Powertrain,U=Network.
B1108-77 Faulty driver's door central locking motor.
B1109-77 Faulty front passenger door central locking motor.
B110A-77 Status - faulty central locking motor - driver's side rear door.
B110B-77 Faulty central locking motor - passenger side rear door.
B10EB-77 Faulty driver's door double locking motor.
B10EC-77 Faulty front passenger door double locking motor.
B10ED-77 Faulty double locking motor - driver's side rear door.
B10EE-77 Status - faulty double locking motor - passenger side rear door.
B10E1-12, B10E1-14, B10E2-12, B10E2-14, B10E3-12, B10E3-14
Circuits of rear central locking relay faulty.
B10EF-12 Circuit of sliding sun roof module faulty (short to voltage).
B10EF-14 Circuit of sliding sun roof module faulty (short to ground or open circuit).
B113D-14 Circuit of sliding sun roof module "general close function" faulty (short to ground or open circuit).
B113D-12 Circuit of sliding sun roof module "general close function" faulty (short to voltage).
B10A2-02, B10A2-11, B10A2-15
Power/signal circuits of crash sensor faulty.
B10A2-00 Faulty signal from crash sensor
U0452-00, U0452-62
Fuel shut-off signal from safety restraints module faulty.
C1A41-21, C1A41-22
Signal circuits of clutch pedal position switch faulty.
B1029-21, B1029-22
Signal circuits of accelerator pedal position sensor faulty.
C1108-01, C1108-12
Circuits for accelerator pedal position sensor and clutch pedal position switch faulty (short to ground or to voltage supply)
B10AF-14 Circuit of cooling fan relay faulty (short to ground or open circuit).
B10AF-12 Circuit of battery protection relay faulty (short to voltage).
B1D06-13 Circuit of left-hand turn signal lamp faulty (open circuit).
B1D06-11 Circuit of left-hand turn signal lamps faulty (short to ground).
B11D3-11 Circuit of left-hand side turn signal lamp faulty (short to ground).
B11D3-13 Circuit of left-hand side turn signal lamp faulty (open circuit).
B1D07-11 Circuit of right-hand turn signal lamps faulty (short to ground).
B1D07-13 Circuit of right-hand turn signal lamps faulty (open circuit).
B11CB-11 Circuit of right-hand side turn signal lamp faulty (short to ground).
B11CB-13 Circuit of right-hand side turn signal lamp faulty (open circuit).
B113C-11 Circuit of light for hazard warning switch faulty (short to ground).
B113C-15 Circuit of light for hazard warning switch faulty (short to voltage or open circuit).
B1D35-24 Circuit of hazard warning switch faulty (switch continuously active).
U2010-11 Circuit of interior light faulty (short to ground).
U2010-15 Circuit of interior light faulty (short to voltage)
B1D13-12, B1D1A-12
Circuit of interior light switch-off delay faulty (short to voltage)
B1130-07 Light switch unit, component fault.
B1D00-11 Circuit of left-hand headlamp faulty (short to ground).
B1D01-11 Circuit of right-hand headlamp faulty (short to ground).
B1D00-13 Circuit of left-hand headlamp faulty (open circuit).
B1D01-13 Circuit of right-hand headlamp faulty (open circuit).
B1098-11 Circuit of left-hand marker lamp faulty (short to ground).
B1098-13 Circuit of left-hand marker lamp faulty (open circuit).
B1099-11 Circuit of right-hand marker lamp faulty (short to ground).
B1099-13 Circuit of right-hand marker lamp faulty (open circuit).
B109B-13 Circuit of license plate lamps faulty (open circuit).
B109B-11 Circuit of license plate lamps faulty (short to ground).
B1A79-13 Circuit of rear fog lamps faulty (open circuit).
B1A79-11 Circuit of rear fog lamps faulty (short to ground).
B1115-11 Circuit of high-mounted stop lamp faulty (short to ground).
B1115-13 Circuit of high-mounted stop lamp faulty (open circuit).
B1095-12 Circuit of windshield washer system relay (on/off) faulty (short to voltage supply).
B1095-14 Circuit of windshield washer system relay (on/off) faulty (short to ground or open circuit).
B1096-12 Circuit of windshield washer system relay (fast/slow) faulty (short to voltage supply).
B1096-14 Circuit of windshield washer system relay (fast/slow) faulty (short to ground or open circuit).
B1D39-14 Circuit of rear wiper relay faulty (short to voltage supply).
B1D39-12 Circuit of rear wiper relay faulty (short to ground or open circuit).
B1C82-12 Circuit of headlamp washer relay faulty (short to voltage)
B1C82-14 Circuit of headlamp washer system relay faulty (short to ground or open circuit).
B10AD-09 Rain sensor/light sensor, component fault.
B10AD-04 Internal circuit of rain sensor/light sensor faulty.
B1133-11 Circuit of heated windshield LED faulty (short to ground).
B1133-12 Circuit of heated windshield LED faulty (short to voltage).
B1097-12 Circuit of heated windshield relay faulty (short to voltage).
B1097-14 Circuit of heated windshield relay faulty (short to ground).
B112D-11 Circuit of heated rear window LED faulty (short to ground).
B112D-12 Circuit of heated rear window LED faulty (short to voltage).
B1C84-14 Circuit of heated rear window relay faulty (short to ground or open circuit).
B1C84-12 Circuit of heated rear window relay faulty (short to voltage).
U2101-00, B1A84-41
Central module configuration faulty.
U2018-41, U2017-41, U3000-51, B1A99-04
Module configuration faulty.
P0604-00, P0605-00, P062F-00
Internal control unit fault.
U3008-01 GEM circuit faulty (open circuit in electronics ground).
B10A5-12 Circuit of anti-theft alarm horn faulty (short to voltage supply).
B10A5-14 Circuit of anti-theft alarm horn faulty (short to ground or open circuit).
B1D17-96, B1D17-00
Internal circuit of the battery backed horn for the anti-theft system (BBS) faulty.
B1D18-96 Internal fault in interior monitoring sensor.
B10D7-81, B10D5-94, B10DA-51, B10D8-00, B10D7-51, B10D7-05, B10D7-94, U0515-87, B10D7-87
PATS system fault.
B11CC-51 PATS transponder not programmed.
B112A-12 Circuit of auxiliary ignition relay in the rear junction box (RJB) faulty (short to voltage supply).
U3003-16, U3003-17
Charging system at fault.
B11BC-15 Circuit of ignition relay faulty (short to voltage supply or open circuit).
B11BC-11 Ignition relay circuit faulty (short to ground).
B1C55-12 Circuit of signal horn relay faulty (short to voltage).
B1C55-14 Circuit of signal horn relay faulty (short to ground or open circuit).
P0462-00 Circuit of fuel level indicator sensor faulty (short to ground).
P0460-15 Circuit of fuel level indicator sensor faulty (short to voltage or open circuit).
B100A-11 Circuit of fuel pump relay faulty (short to ground).
B100A-15 Circuit of fuel pump relay faulty (short to voltage or open circuit).
B10C0-14, B10C0-12
Fuel pump circuits faulty.
B1182-51 Tire pressure monitoring module configuration faulty.
C1D21-05 Signal of tire pressure warning sensors faulty.
C1D18-00 Not possible to locate the tire pressure warning sensors (signal from at least two tire pressure monitoring antennae faulty).
C1A56-93 Front left tire pressure warning sensor inoperative.
C1A56-16 Signal of front left tire pressure warning sensor faulty (battery discharged).
C1A56-86 Signal of front left tire pressure warning sensor faulty.
C1A58-93 Front right tire pressure warning sensor inoperative.
C1A58-16 Signal of front right tire pressure warning sensor faulty (battery discharged).
C1A58-86 Signal of front right tire pressure warning sensor faulty.
C1A62-93 Rear right tire pressure warning sensor inoperative.
C1A62-16 Signal of rear right tire pressure warning sensor faulty (battery discharged).
C1A62-86 Signal of rear right tire pressure warning sensor faulty.
C1A60-93 Rear left tire pressure warning sensor inoperative.
C1A60-16 Signal of rear left tire pressure warning sensor faulty (battery discharged).
C1A60-86 Signal of rear left tire pressure warning sensor faulty.
C1A57-11 Circuit of front left tire pressure monitoring antenna faulty (short to ground).
C1A57-12 Circuit of front left tire pressure monitoring antenna faulty (short to voltage supply).
C1A57-13 Circuit of front left tire pressure monitoring antenna faulty (open circuit).
C1A59-11 Circuit of front right tire pressure monitoring antenna faulty (short to ground).
C1A59-12 Circuit of front right tire pressure monitoring antenna faulty (short to voltage supply).
C1A59-13 Circuit of front right tire pressure monitoring antenna faulty (open circuit).
C1A61-11 Circuit of rear left tire pressure monitoring antenna faulty (short to ground).
C1A61-12 Circuit of rear left tire pressure monitoring antenna faulty (short to voltage supply).
C1A61-13 Circuit of rear left tire pressure monitoring antenna faulty (open circuit).
C1A63-11 Circuit of rear right tire pressure monitoring antenna faulty (short to ground).
C1A63-12 Circuit of rear right tire pressure monitoring antenna faulty (short to voltage supply).
C1A63-13 Circuit of rear right tire pressure monitoring antenna faulty (open circuit).
U201F-87 No communication possible with the remote control/tire pressure monitoring receiver module.
U201F-04 Internal fault in remote control/tire pressure monitoring receiver module.
B1D21-62 Remote control not synchronized.
B1B71-11 Circuit of evaporator temperature sensor faulty (short to ground).
B1B71-13 Circuit of evaporator temperature sensor faulty (open circuit).
B10EA-12 Circuit of electric booster heater faulty (short to voltage)
B10EA-14 Circuit of electric booster heater faulty (short to ground or open circuit).
B112B-07 Steering wheel module switch faulty.
B10AC-95, B10AC-87, B10AC-86
Speed control system, system fault.
C2003-49, C1D22-49
Internal fault in speed control system switches.
U2108-53, U2107-53
Adaptive speed control system, system fault.
U0401-00 Invalid data from PCM to distance warning system module.
U0405-00 Invalid data from distance warning system radar unit to distance warning system module.
U2001-87 Missing signals from anti-lock braking system module, PCM, distance warning system radar unit.
U0515-00 Feedback from the keyless vehicle module faulty.
B10E5-11 PCM wake-up signal from GEM faulty (short to ground).
B10E5-15 PCM wake-up signal from GEM faulty (short to voltage supply or open circuit).
U0181-00 No communications possible with the headlamp leveling module.
U0155-00 No communication with the electronic instrument cluster.
U0121-00 No communication with the anti-block brake system module.
U0100-00 No communication with the powertrain control module (PCM).
B112B-87 No communications possible with the steering wheel module.
B112C-87 No communications possible with the interior monitoring sensor module.
B1D17-87 No communications possible with the anti-theft alarm signal horn with integrated battery.
U0231-87 No communications possible with the rain sensor/light sensor.
B1130-87 No communications possible with the light switch unit.
U0214-00 No communications possible with the keyless vehicle module.
U0104-00 No communication possible with the distance warning system radar unit.
U0199-00 No communication possible with the driver's side front door module.
U0200-00 No communication possible with the passenger side front door module.
U0252-00 No communication possible with the trailer module.
U0128-00 No communication possible with the electric parking brake module.
U0122-00 No communication possible with the damper control module.
U0101-00 No communication possible with the transmission control unit.
U0164-00 No communication possible with the electronic temperature control module.
U0001-00 No communications possible via the HS CAN bus.
U0010-00 No communications possible via the MS CAN bus.
rondeo is offline   Reply With Quote Multi-Quote with this Post
