Old 27-03-2006, 10:53 PM   #1
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Default Ecu
I am going to put the new cam in that i got and i was wondering if i would need a chip or a new ECU or will the Fairmont one do it ok, the Crow cam is the 2222519 and i got valve springs with it and i will be putting new extractors on soon im hopeing for around 130RWKW is this in reach
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2006, 11:09 PM   #2
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
i was just looking at the specs and that cams for the ef/el isn't it?
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2006, 11:27 PM   #3
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
it will fit into a EB so i am told if not i will be cracking heads
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 28-03-2006, 07:52 PM   #4
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Dose anyone know if the cam will run on the ECU
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 28-03-2006, 07:53 PM   #5
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Or will i need a chip
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 28-03-2006, 08:47 PM   #6
EB Pete
EB Pete's Avatar
well this is what crow say 'mild performance cam EF-EL to 1/98 suit std computer. improved exhaust recommended'.
Old 28-03-2006, 11:39 PM   #7
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
will the cam make a big difference with a set of extractors and valve springs and will it fit the EB coz if it dosnt i don't know what im going to do with it
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 28-03-2006, 11:54 PM   #8
EB Pete
EB Pete's Avatar
here's a number for crow 03 9357 0469 and ask for wendy. she knows pretty much everything about their cams. i rang her about mine. i'm getting the stage 4 part number is 2222543 it's a custom grind and she told me everything i needed to no. i'm getting the xr6 valve springs they sell, and the vernier gear (make sure you get that) and i got pace maker extracters aswell and 2 1/2 system but haven't built it all yet so don't know how it will go but i need a chip or probably a new ecu but you shouldn't with that cam. maybe just a chip, not sure
Old 29-03-2006, 12:16 AM   #9
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i might look like a bit of a dumb *** but what dose the vernier gear do
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 29-03-2006, 01:06 AM   #10
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
compensates for any error in the grind of the cam... to set it at true TDC basically..
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 07:05 PM   #11
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
How much do they cost,
one other Question is
how long do i allow my car to be off the road while fitting a cam and valve springs and could some give me a rundown on how to do it and what tools i need
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 29-03-2006, 07:29 PM   #12
OED666
OED666's Avatar
a vernier wheel you can get for $150...
you dont have to have a chip... my car was putting out around 150RWKW with no chip.. just cam, and exhaust...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 01:07 PM   #13
heckaz performance
The cam will fit your head.
The cam should crack the numbers you are chasing,
I use the 2222549 cam, with stock springs, and it has .530 lift,
yours runs .493, so you probably wouldn't need springs.
You don't need a vernier gear, unless you want to spent $100's for no gain (maybe 2kw)
A cam can be fitted in a day easy, half a day even, for about $150- $250 depending where you go.
heckaz performance is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 09:45 PM   #14
EB Pete
EB Pete's Avatar
how can my cam be 'better' with smaller lift?
Old 01-04-2006, 02:48 AM   #15
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i got the XR6 springs are they still worth putting in and how long would it take a person like myself to fit as i have never done a cam before.
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 02-04-2006, 01:48 AM   #16
heckaz performance
Apperently J^% reckons there is no measureable difference between them and the stockers.
