How hard is it to change a starter motor in a EB I6 falcon? I got a new BXF 129 Bosch starter for $141 as mine is starting to play up by not engaging, just making a whine until i press the air con switch then she kicks over (don't ask me why) I hope i have purchased the right part from supercheap as the guy reckons that all Ford 6 cylinder engines from 1966 to 2005 share the same starter motor, i always thought that the early falcons had a bendix spring and the late model falcons had a reduction gear drive?
Any help would be greatly appreciated Thanks Rexy74 |
Shoot.
Yeah they're pretty much all interchangeable, but the AU one is smaller and a bit more powerful if I recall correctly.
There are a few threads on replacing the starter motor.
20V Turbo |
ORSM FORD CRUSIERS
starter motor are very easy to change they are only held on by two bolt top and bottom. its a simpe procedure. bosch only make one size of starter motor that fits from xp falcons right up to au's. thay are the same the guy from supercheap is right. so i think u might have soem other little gremlins in ur car.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
