#1 | |||
A humorous statement
I've done a search. However I can't seem to find anyone having trouble fitting the XR8 snorkel to a series one forté. It goes on easy enough, its just the bonnet won't close and I don't understand why, the only difference between it and the smaller one is the width of the throat. Any ideas?
Black manual AU1 S. S Quote:
what part of the snorkel is hitting the bonnet?
#3 | |||
I can't tell. I filed some off the lip on the bottom seeming that was getting marks on if. Also I can see where the rubber is going and it seems to be on the correct spot. Could it be at the back where it starts slopping down?
Just slidin'
Did you leave the screwdiver under there? Gets me all the time.
MD Mondeo - For the family
#5 | ||||
Just slidin'
Ohh well, was worth a try. Every time Im under the bonnet, I cant get the bonnet to shut. Theres alway a screwdriver, Socket, something sitting in there not letting it close. I actually found a peice of quartz in there the other day, it was the size of a baseball. I have no idea how it got under there, or for how long its been under there. Weird.
maybe check the rubber on the underside of the bonnet, where its curved for the snorkel....might help??
you didnt remove the airbox did you? maybe its not sitting down properly
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
#8 | |||
Didn't move the airbox. I used hair gel to find where it was touching, seems to only be on the rubber. It looks like for some reason the metal where the snorkel sits is propping the new snorkel up. So I'm thinking I may have to bend it with vice grips or something. Its never a straight swap! :P
Make sure it sits perfectly within the indentation in the radiator support panel, I've heard on some snorkels you have to trim the lower section corners (where the screws sit) as they don't follow the profile exactly which causes the snorkel to "sit up".
Removed by laminge |
Question, and sorry to highjack.. are there two different Tickford snorkels? Say a Xr6 one, and a Xr8 one.. or is there simply one?
Just slidin'
Just one.
#12 | ||
Flying high...
Its very odd that your snorkel doesnt fit. I had no problems fitting mine, i just screwed it in. Have you got any pics of it installed? I might be able to compare it to mine and see if there is any difference....
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel, 3" mandrel intake, K&N pod in the box, Polished Rocker Cover. |
#13 | |||
I had to drive the car so the old snorkels in. I have butchered this new one a bit in my attempts to get it in. And yes it does seem to be sitting up as you say Dok. However it seems to be caused by the side closest to the engine where the snorkel sits.
#14 | ||
Have you got any pics. I wonder if it is the angle at which the snorkel joins the airbox?
FG2 XR6T KIA Cerato 2022 Kawasaki Z900
#15 | |||
I'll get pics of it tomorrow. As a side note it set me back $30 from Keira Ford in Wollongong. From what I've read thats about as cheap as you can get one.
#16 | |||
Mine went straight in, the only thing with it, is that the screw holes are slightly to close together causing the bottom lip seems to bow up in the middle
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
#17 | |||
#18 | |||
Flying high...
#19 | ||
well i have an au1 forte, and mine went straight in, no problems...maybe try adjusting the bonnet stops? they may have been wound out a bit more at some stage
#20 | ||||
P.S. And why the heck doesn't firefox know what Tickford is yet? I write it enough :P
#21 | ||
www.TUFFCARPARTS.com
My BAXR6T one went on perfectly. If it doesn't line up, maybe you should ask for it to be swapped with another.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
#22 | ||||
#23 | |||
Blown 5L coming
not sure if anyone else has picked this up, but we started talking xr8 snorkle, but now we are talking xr6t....did i miss something? i picked up an xr8 tickford snorkel off an au and was straight swap on my s2 wagon.
![]() ![]() i think it looks good with my little touch anyway ![]() col
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
#24 | |||
#25 | ||||
#26 | |||
Audi S3
my xr6t snorkel went straight in. i swapped it over when i was 5 minutes early for work once.
#27 | |||
#28 | ||
They are the same thing. I believe that the XR6T snorkel is even listed as the replacement part for the AUXR8 snorkel which is no longer produced.
#29 | ||
does changing the snorkel to a slightly bigger one make any noticable difference as everyone seems to do it
#30 | ||||
