24-04-2007, 11:06 PM | #1 | ||
RS2000 COSWORTH
The New Generation Escort.
25-04-2007, 12:03 AM | #2 | ||
well thats cool
1628 Escort Project Thread 67.3 RWHP - Paramount Performance Dyno DJ Automotive Tuned with proper jets http://fordforums.com.au/showthread....4&page=1&pp=25 |
25-04-2007, 12:17 AM | #3 | ||
Ute Forum Moderator
I was expecting to see a 1990s one - awesome stuff, can you tell us more about the car?
25-04-2007, 01:44 AM | #4 | ||
classicford.mine.nu
Very nice Sir!
25-04-2007, 03:43 PM | #5 | ||
That is the coolest thing I've ever seen....
I want one!! Please give us some more info!! |
25-04-2007, 07:57 PM | #6 | ||
Old enough to know better
Very schmick indeed!! Tell us more
Manual 2003 Machine Silver 5 Door LR Focus Zetec. Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior. www.cardomain.com/ride/2773918
25-04-2007, 09:53 PM | #7 | ||
I think I have photos of that car at a small ford club show do you have a custom panel in place of the rear seat
26-04-2007, 04:27 PM | #8 | ||
RS2000 COSWORTH
Hi everyone. Thanks for the kind words.
This is a 1980 Ford Escort RS2000. (Rebuilt in 2002, this is the second motor in it, was on carbies N/A.) It has an exorbitantlist of modifications. Some of the features are below: 1. YBB Sierra Cosworth T3 turbo engine. 220kW atw on 18psi. Only done 1500kms. Much more power and boost to be extracted from this very shortly but 220kW power in 950kg car is absolutely berserk. Many grins. Custom radiator, intercooler and oil/air separator, all hoses and fittings silicon/braided or anodised ally. Steel case 5 speed gearbox. 2. Autronic SMC ECU, with Autronic 500R CDI direct fire igntion and 4x MSD Blaster ignition Coils, magnecore leads and Bosch injectors and 044 fuel pump with 2.2L surge tank. 3. 2 seater with rear lounge removed and 2x Sparco Corsa race seats. EL Falcon Carpet. 4. Extra gauges (Boost, fuel psi and oil temp), in dash tacho changed to 10,000rpm from use with previous N/A Cossie Motor 5. Coil overs with 275lb springs on 3in shorter strut and insert, reverse eye lowered rear leaves, bilstein shocks, panhard rod and radius arms. Adjustable strut tops and 24mm swaybar. 6. 305mm rotors and 4 pot callipers, Borg Warner 8.75 limo diff 4.11:1 with 260mm disks and pbr callipers. 16x7 Superlites and 205/45/16 Kumho semi slicks (turns them in 3rd gear when cold!) .....and much more. (it will not let me add more photos, says exceeded my allowance - That is BS at 400kb!) Last edited by EskyCosworth; 03-06-2011 at 10:49 PM. |
26-04-2007, 04:30 PM | #9 | ||
Tricolore Tard
Very nice car you have there !
Get some more pics up
26-04-2007, 04:33 PM | #10 | ||
RS2000 COSWORTH
So how do we get our file upload increased to more than 5 photos?
26-04-2007, 04:34 PM | #11 | ||
Tricolore Tard
Sign up to the euroford gallery @ http://www.eurofordclub.com/gallery
Once signed up, you can upload as much as you want there ( its my webspace you see ) Cheers Chris
26-04-2007, 04:38 PM | #12 | ||
RS2000 COSWORTH
Are you euroford members going to come along to the CLASSIC FORD CRUISE No.13?
The 12 previous have been awesome! Seano would have contacted euroford... |
26-04-2007, 04:43 PM | #13 | ||
White Lightning
so totally awesome, just, rad. i've regressed to early ninties surfer mode it's so good. its like tubular dude. seriously though, i love escorts and rs2000's are hot, but thats toooo good. well done. cant wait for more pics.
26-04-2007, 09:10 PM | #14 | ||
I check out this website a few times a day jut to get another look at that car. I love it!! Makes me want to sell the rex and pump the money into my RS!!
Well done BLOODY Brilliant!! |
27-04-2007, 09:36 PM | #15 | ||
Mr Focus
Where about did you get the Cosworth Turbo from?
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. |
28-04-2007, 10:50 PM | #16 | ||
Ute Forum Moderator
There is also the forums gallery you can use, go to the link at the top of the page
29-04-2007, 01:54 PM | #17 | |||
RS2000 COSWORTH
29-04-2007, 04:41 PM | #18 | ||
What is involved in fitting the engine??
Does anyone know where and about how much for a cosworth 2nd hand?? |
29-04-2007, 08:31 PM | #19 | ||
Ute Forum Moderator
Haha, lots!
29-04-2007, 08:37 PM | #20 | ||
I was afraid I'd get an answer like that.......
29-04-2007, 09:06 PM | #21 | ||
RS2000 COSWORTH
Hi guys - there is just so so so much to say when it comes to the Cossie conversion. The initial cost of the engine is about 4K (buy only a good one)...If you build a monster and do it properly then you will buy some tasty aftermarket electronics and injectors etc along the way and watch to cost go up (you can just keep it standard if you like). Like with all things, buying the good gear will result in a huge grin and many years of happiness. I recommend it only to the extreme Escort and Cosworth fanatic. Else just go for a turbo pinto with sierra injection.
Most importantly you must upgrade the gearbox/diff and brakes to cope with the torque. Good luck............ The motor uses the same block but just a stronger version 205 or 4x4 200 block...... |
29-04-2007, 09:07 PM | #22 | ||
What an absolutely awesome Esky !
My dream car is an RS1800 BDA, but I don't have 20,000 pounds for the engine to build a replica. Your RS must be awesome to drive - I'm jealous mate ! |
29-04-2007, 09:19 PM | #23 | |||
RS2000 COSWORTH
30-04-2007, 07:36 PM | #24 | ||
on the way to the RSL
Indeed a awesome car!!
Has it been engineered? I'm looking at Engineering my Mk2 with a 2L turbo EFI pinto, and Im curious to know what they made you do. Once again ace Escort!! I want cossie power!
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9" 8.9x@160mph+ |
30-04-2007, 08:51 PM | #25 | ||
Boost Junkee!!
Nice car you have there mate!! It seems vaguely familiar!!
30-04-2007, 09:43 PM | #26 | |||
RS2000 COSWORTH
01-05-2007, 12:10 AM | #27 | ||
Perth XR5'er
Agree : : :
Ford Rallye Sport Club of WA; Member#64: Barbagallo Short: 1:01.1779 Barbagallo Long: 1:12.4649 Collie: 55.90 K&N Gen2 57i CAI / 2XS RIP / Airtec Gen3 IC / Mongoose Dump Pipe / Outlaw 200cpsi Cat / Milltek Ultimate Race Catback / Whiteline 24mm RARB / Whiteline FALK / BC Racing BR-Spec Coilovers / RSR Rear Camber Arms / Ferodo DS2500 Pads F&R / Goodridge Braided Brake Lines / Elevate Torque Mount / DS MOD C / MkII RS Clutch & DMF / Quaife LSD |
01-05-2007, 01:22 AM | #28 | ||
Awsome car mate! I had a RS Saphire Cosworth that was great fun. Same engine in a 300kg lighter car would make it insane. I have considerd the same conversion into a capri. Youve gota love the old eskies!
Cheers Brett |
01-05-2007, 10:12 AM | #29 | |||
RS2000 COSWORTH
01-05-2007, 10:14 AM | #30 | ||
RS2000 COSWORTH
I hope to be able to do some decent times around Wakefield, Oran and Eastern Creek...and due to peer pressure I would say I awill attend at least one drag night to see what it can do, but my interest lies in thrashing it around a track.....and blowing the doors off 'rice burners' in this old beat up esky, well not too beaten up.
